LQ4 nicked piston, replace or run it
Long:
Engine is mostly stock 2004 LQ4 with mild cam and valve springs(BTR platinum) swapped in. Engine has super low mileage for its year: ~65k. I had to pull the head when rod #7 snapped due to fuel hydrolock
Only good thing so far is cylinder #7 is in good shape.I can't see what nicked piston #1 above.
Aside from the cam/valve springs, there is nothing else on the engine. No performance adders. It is used in an offroad setting when I might rev the engine up to ~6k rpm.
