Valve Spring Change with engine in car.
Old Apr 9, 2021 | 08:07 PM
2001ws6ft's Avatar
For an LS1 with 241 cylinder heads it is separate so when you go to purchase the FELPRO valve stem seal kit your only going to get the valve seals. When you pull the valve spring and remove the valve stem seal you can then remove the seat the valve spring sits on. When replacing the valve stem seals the black ones are for intake and brown ones for the exhaust.
Does this kit work?
https://www.summitracing.com/parts/FEL-SS71039
Old Apr 9, 2021 | 08:34 PM
01CamaroSSTx's Avatar
FelPro SS70945 and they're all the same color and doesn't matter whether its for the intake or exhaust.
Old Apr 10, 2021 | 02:21 PM
patSS/00's Avatar
Get the hat style seals, they're a much better design, and they work fine on 241 heads. Also much easier to remove when you have to.
Old Apr 10, 2021 | 02:26 PM
The only time I ever have a problem removing any of them is when I can't find my pliers or vice grips.
Old Apr 10, 2021 | 02:55 PM
2001ws6ft's Avatar
so this would be the correct part?
Old Apr 12, 2021 | 12:00 AM
weinerschizel's Avatar
I did it on my 4th gen with LT1. You will want this tool:
http://vincihiperformance.com/TOOLS%...NT%20PAGE.HTML
Makes the job pretty easy. I would go with dual valve springs. Half the chance you drop a valve
Old Apr 13, 2021 | 12:14 PM
00pooterSS's Avatar
Lowering the K member is really really easy, and makes a huge difference when working on the top end in a 4th gen.
But I have done valve springs in a F body before without lowering the k member and it was not horrible. Not fun but not too bad.
