Check internals after hydro lock
I got a 6.0 that i swapped into my squarebody truck and i had a fuel injector stick wide open and while trying to diagnose it had filled cyl 3 with gas and i went to start it and hydro locked it. Well i pulled the pan and and looked inside afterwards to see if i wrecked my motor before trying to start it, nothing looked out of place and i looked around and most things said a low rpm hydrolock shouldn't be that bad so put it back together and sounds like it has a slight rod knock. So im planning on pulling the motor later on to see what exactly is wrong and make a plan for it. My big question tho is how to i know what might be bad and how to check for sure. This is a fresh built motor and rods and pistons are new and really dont want to toss it all and start over if i dont have to so how would one check pistons and rods for any damages that arent obviously to the naked eye?
i did find a tooth chipped off my flywheel and broken start parts in the bell housing but thats about it
