Effects of valve lift on part throttle.
Old May 4, 2021 | 06:56 PM
Doesn't overlap determine drivability to a certain degree? Lower overlap is easier to drive on the street, or so I've heard.
Below say...2500 rpm...yes.
Old May 5, 2021 | 02:17 PM
Z28SteveA4's Avatar
Overlap can make or break a cam depending on the use of the cam. If you want a very drivable car overlap is going to make that very difficult. Like mentioned above cubic inch, head efficiency, compression and a very good tune help with overlap and drivability but there is still a limit if you want a “streetable” cam.
