Help noise on decel
If it is still there, pull the valve cover and inspect
If you don't notice anything replace the lifters
EOIC when the Exhaust Valve begins to open the Intake Valve is on the base of the camshaft and you can work on it and once your done there you turn the engine over until the Intake Valve has opened and begins to close and then you can work on the Exhaust Valve. Do this for each cylinder or just remove all the rocker arms and pushrods keeping track to what goes where and inspect the parts and then bolt them all back down and torque everything to 22ft lbs regardless if your on the base of the cam or not. I've heard of people doing this but I certainly do not recommend it. This is where a remote starter switch come in real handy.
Two reasons why I installed a solenoid up by the battery. One to get the power off of the starter at all times and second for connecting my remote starter switch. Even with the key out of the ignition you will be able to bump the engine over to watch the valve events when the remote starter switch is connected to the solenoid.
