2500HD LQ9 SS2 cam
My thought was that even if it did sacrifice some torque down low, it would be nice to downshift into third pulling a hill at around 4k on the highway while towing and have significantly more power there. Does this logic work or am I going to have too much trouble getting any load moving from a stop? On Holdener's dyno chart it does make more power at 2500 than the stock cam. The stock stall is like 1800, so it would only be tough for about 700 RPM I suppose, which perhaps a converter would completely rectify... I'm new to the LS engines. I hear they love more cam so I thought maybe this would work. Any wisdom is greatly appreciated! Thank you
Throttle to the floor no brakes burnout in my previous setup with the SS2
I looked closer at Holdener's dyno chart comparing SS2 to stock and realized he didn't show power or torque below 3k for the SS2. So, it does make more than the stock cam everywhere, starting at 3k... I'm guessing below 3k the stock cam makes more. He uses an LY6 with an LQ4 cam, and the LY6 is pretty comparable to the LQ4 other than the rec port heads. I'm not sure if my cathedral port heads would help it down low in the RPM compared to the rec port or not.
Maybe since it's a 6.0L rather than a 5.3 or 4.8, with a small tire and 4.10 gear, it won't be too bad? I wish the 4L80 had a deeper first gear... I don't know, what do you guys think? Is this a bad idea? I suppose I could try it and change it out later if it's too bad, or fix it by swapping in a NV4500 like it should have anyway, haha.
Kyle has some great tuning tutorials
I think the SS2 is way too big for an lq4, especially in a truck. Not enough compression. I think it's the end of that video where he tests some summit cams as well and a smaller cam actually made more torque under the curve, same hp. I think it was a 218/227. That would be way more snappy off the line and not bleed off so much compression.
Now if you wanted to switch to 706 heads, the ss2 might not be a bad choice. Keep the cam duration and ports as small as you can to reach desired hp and you have a faster engine with better mpg and response.
Im setting up a similar truck, new to the ls game.
To run a ss2 cam besides getting hp tuners and a af gauge
what is needed to get it running good enough for a road trip.
do i need to change injectors to get it drivable,if so whats a decent one to get.
throttle body, etc?
eventually i will be learning to tune it to get max hp and just have fun frying the tires but still use it as a truck.
thanks.
throttle body, etc?
thanks.
i know its not the perfect set up and since im rebuilding the motor(rings, bearings) i may put a better converter in it while i have the motor out.
i already have the cam,just gonna stick with it.
later on i may drop it in a better project car...
mostly wanna learn how to tune with hp tuners as the next peoject is a 2wd truck wanna put a turbo on and will need to know how to set up the computer on that...
Only been tuning carbs,might aswell learn this stuff also.
As far as tuning for a road trip.....either plan on lots of reading and test drives or just take it to someone. Setting idle and wot is nothing compared to part throttle tuning and knock tuning, tip in, slight load, trans shift points......
no tuner close by. Im hoping to find someone who would share a base file i could use as a starting point.
First impressions: the cam sounds awesome at idle, which is a plus. It's a little soft down low, maybe not any worse than a stock truck, but pulls pretty good above 3,500-4k. I know I'm leaving a lot of power on the table without doing any real tuning. I also need to uncork the exhaust side. I still have the full stock exhaust. I want to do long tubes and something about the trash can sized muffler, but I don't want ANY drone or excessive noise, so I'm kind of torn on that issue. Any tuning and exhaust suggestions would be much appreciated. It sounds like I need to upgrade to big block injectors, like yesterday. And obviously, a higher stall converter would go a long way as well, which I'll get to eventually.
Overall, my goal is a stock appearing, beat up work truck, but with a little surprise power hidden beneath the cloak of innocence. Thanks again for all the help and suggestions.
But the biggest improvement will come from a higher stall converter. Stock is 2200 I think for the LQ4, 1800 for the half tons. 2500 would be good. 3000 if you really want it to be snappy. But the higher you go, the mushier it makes the power delivery under light throttle until the converter locks up.
I'm confused, if I don't use an air/fuel gauge and want to read the O2 voltage on HPtuners, don't I have to unplug an upstream sensor to plug in the wideband, and won't that put it in open loop?
Any recommendation on injectors to get? I see talk of 8.1 marine injectors, flex fuel injectors, stock big block injectors... I don't know, I just want whatever will work that is affordable and easy.
I logged a full throttle run to 5500 rpm and noticed a few things. At about 4k it had 27* of advance, 22* at 4500, 18* at 5k, and 15.5* at 5500. That doesn't seem right. It reads 0.0 knock retard on the list on the left, so I don't know why it would be pulling timing.
