STREETSWEEPER VS TSUNAMI cam
I'm leaning more towards the Streetsweeper as from what i have seen on dyno printouts, the cam pulls hard all the way to 6500 and then flattens out to 7000. Car is running an A4 and will be running a 4k stall.
Any advice, good or bad, is appreciated.
Cheers
Lee
Cheers
Lee
Id love to see a pic of the Valiant. I used to have a 69 and miss it. If you dont, text me a pic(s) please.
Rob (956) 802 7700
Hey, fellow Aussie. I cant help you with the cam question as I use small cams but in case you didnt know, there is usually a 10-15% variation with dyno results between the USA and AUS. So, if you end up with lower dyno readings, don't let it worry you. Best of luck with the mods.
Cheers
Lee
Cheers
Lee
