Best LS Porting and Polishing Service
Old May 28, 2021 | 03:08 PM
mrf1984's Avatar
Default Best LS Porting and Polishing Service
I have a set of 799 heads that I am going to install on my 5.3 LM7. I'm looking for a solid CNC porting, polishing service. Would love some recommendations.
Old May 28, 2021 | 03:36 PM
Nowadays porting is all that's needed, especially with CNC. Polishing is not done as much, as the CNC surface is good for flow.
Old May 28, 2021 | 03:53 PM
99Silver6.0's Avatar
When I get ready Im most likely going with Frankenstein.
Old May 28, 2021 | 06:52 PM
wannafbody's Avatar
Best price is Katech or TSP. If you are getting over $1000 for porting you'd probably be better off getting aftermarket castings.
Old May 28, 2021 | 07:14 PM
Sway Tale's Avatar
I literally just posted about not wasting money on porting 15 year old heads that will probably end up leaking coolant. Run them as is. Its's really not worth on it a 5.3.
In fact you will make more power with 862/706 heads on 5.3 and a thinner headgasket. You would have to mill the 799s, lose piston to valve clearance to make it even worth it and port them on top of that. Did I mention having to buy a different length pushrod if you milled the 799s?
If you are going boost then you will only see maybe 20-35whp on the dyno. That's usually 1-2 psi of extra boost.
The power difference between a 5.3 with ported 799/243 and a 6.0 with stock heads is still huge.
Old May 28, 2021 | 09:00 PM
01CamaroSSTx's Avatar
How much can you expect to gain from ported cylinder heads? Is a 50hp gain worth 1K when the bottle can make three-four times that much?
Old May 28, 2021 | 09:19 PM
SoCalDave's Avatar
You can also run the 799 heads stock. Go on Instagram or search Youtube to find someone to port your heads. It's way worth it.
Old Jun 3, 2021 | 12:52 AM
DualQuadDave's Avatar
TEA Stage 2's are the best, by far, for a cnc'd stock cathedral. AI was real good, but having major business issues, not currently recommended. I have no idea wtf anybody is recommending in this thread. FED cant port a stock cathedral worth a ****, and cheapo porting is questionable at best. If you are paying for a service, get your $$$'s worth. The TEA's are proven to make power. Porting a set of 862's is better, just for the better compression. Do a lot more homework before just throwing $$$ around.
Old Jun 3, 2021 | 01:14 PM
SoCalDave's Avatar
Price is not always connected to quality of work. Stock or ported will work. Remember it's effective and efficient cylinder filling that you want. The throat and bowl are a major pinch point that needs work.
Old Jun 3, 2021 | 02:35 PM
Stampede4ever's Avatar
Hand finish a set yourself.
Old Jun 3, 2021 | 02:49 PM
low2001gmc's Avatar
MASS seller approved
Always cheaper to go with what you got. If you got 799s already, just mill .030 to slightly increase compression. 799s airflow is quite sufficient for a 5.3. You can still run a decent sized cam with consideration for intake duration and lsa. Use money instead for a better intake like a fast. Or if you have an ls6, then maybe stall and gears...
