Got a LS1 that has not been cranked over in 8 years
This engine has been sitting for 8 years! I need some advice on what I should do and how to do it. Before I crank it over. It’s in a 1959 Biscayne Chevy wagon!! I have good mechanical skills but I know nothing really about this engine except that it was Built by Turnkey Engines in Oceanside. I have no specs but I was told it has a cam and pistons! It’s what they call a 5 wire engine! It is run by a Mefi 4 Delphi computer. I added some pics of the engine
I have some wiring to finish as you can see
First thing I would do before trying to turn it over with a starter would be to remove the plugs in case there's water sitting on the tops of the pistons and then I'd see see if it can turn over by hand. If that checks out then maybe throw some new plugs in it and squirt a little oil down into each cylinder before your fire it off. Water sitting on the tops of the pistons will eventually corrode the cylinder walls and it might run for a little while but it will soon be done in. Bore scope and compression test would be handy here.
Also be good idea to change the oil and filter if haven't done so already.
The following 2 users liked this post by 01CamaroSSTx:
60Nomad (06-10-2021), Old Buzzard (06-12-2021)
The following 3 users liked this post by WE TODD DID:
The following users liked this post:
60Nomad (06-11-2021)
60Nomad (06-13-2021)
I bought a 1953 Chevy Bel Air back in 2017 which had originally been in Carlsbad, and it's fitted with a Turnkey Engine supplied 375hp LQ4 with the Mefi-4 ecu. It seems to run ok, but I think the mefi-4 system isn't the best solution as it isn't as easily tuned as the GM original - especially here in Scotland (i.e. no one has a clue lol) - plus it's not the best on fuel. I think that just a general service as folk have already suggested will have it up and running, but how well will depend how it's been set up. I note that Turnkey no longer do the mefi- 4 set up - I wonder why. You're entire set up looks very similar to mine, so possibly it's had the whole Turnkey package.
Pete
Pete
60Nomad (06-12-2021)
Pete
Pete
Yes, my 53 chevy runs rich too, and isn't as quick as i think it should be. The mefi-4 seems very basic, but I suppose it is usually used in boats and sandrails, so I'd assume it's quite rugged. The wiring harness is quite tidy, and fortunately long enough for me to move the ecu and associated relays and fuses inside the car. This was due to water related issues with a fuse. I just didn't recognise the fuse holder as being one, so took a while to diagnose loss of power.
The engine does seem very healthy though, but I may have to bite the bullet and fit a package that I can get tuned properly.
Pete
Pete
So after much procrastination and reading here’s the handy little gadget I made to get Marvel mystery oil into the plug holes. squeeze bottle from ace hardware, 3 feet of quarter inch tubing I had a quick shut off valve. It worked great. I figured PB blaster would get on the cylinder walls so I bought the one with the long tube... it worked quite well too. It even works inverted! So I’m gonna let it soak and turn it over by hand tomorrow!
