What valvesprings...
Old Jul 20, 2004 | 05:17 PM
God of Thunder's Avatar
Default What valvesprings...
should i use with an FM13 cam? single, double? i have tried searching, but can't really seem to find it. thanks a lot
Old Jul 20, 2004 | 06:46 PM
JDPZ28's Avatar
Hey Walter,
get the Patriot duals, Texas Speed carries them. I broke two Crane duals with that cam and they only had about 10k miles on them.
Old Jul 20, 2004 | 06:58 PM
soundengineer's Avatar
yeah.. patriot gold duals would be a great choice....
Old Jul 21, 2004 | 09:17 AM
thanks guys
Old Jul 21, 2004 | 10:45 AM
52172's Avatar
If you got the cash go with comp 921's they are truely the best.
Old Jul 21, 2004 | 11:02 AM
MeanWS6's Avatar
price not being an issue, what are better the COMP921's or Golds?
The way I look at it, spend a little more now and save alot of frustration later
Old Jul 21, 2004 | 12:35 PM
TVWilkes's Avatar
The comp spring cost more,but is it better.Both springs are made of quality material.The Patriot "GOLD" spring is made of super pure chrome silicone vanadium.The spring is also electro polished,to improve spring life and remove stress risers.The comp spring is probally made of chrome silicone but is not polished.I worked with the spring companies engineer to develope the "GOLD" spring.Neither company manufacturers the spring,we have a spring manufacturer build them.
Old Jul 22, 2004 | 01:10 AM
Blacker's Avatar
The Crane Duals from Thunder Racing will work great. Can't beat the price either.
Old Jul 22, 2004 | 06:28 AM
JDPZ28's Avatar
see my previous post^.
Old Jul 22, 2004 | 09:34 AM
i think ill be going with the patriot golds. thanks a lot guys
Old Jul 22, 2004 | 10:25 AM
DanZ28's Avatar
I'm running the crane dual 832's with the Trex and no problems so far. Is there some sort of breaking issue with these, or is this a one time occurance.
Dan
Old Jul 22, 2004 | 11:07 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
We run the Patriot doubles mainly because of the better pressures.. The crane's have also worked well for us if we shim them up to get more pressure from them
Old Jul 22, 2004 | 11:25 AM
JDPZ28's Avatar
^ what he said! I had some valve float on the dyno with my Crane duals/FM13 combo @6300rpm's, due to lack of seat pressure. Also I think I am the only one(that I have seen or heard of anyways) that has broken one(actually two ).
Old Jul 22, 2004 | 01:52 PM
im assuming single springs wouldnt be any good due to the aggressive lobes, right?
