Rebuild top end
I’ll keep it short and to the point. I have bad lifters, I’m going to drop the motor slightly to make it easier to remove heads but can you guys pls help me create a part lift of everything I should replace while I have the heads off? I’ve only done knock sensors and radiator. I’m thinking oil and water pump, theromstat, head gaskets, intake gaskets, timing chain, belt, Valve cover gasket, air filter, and I already have spark plugs n wires. I’d really appreciate other info, also do y’all think I need a new cam? My lifters started to make a ticking noise I have a video on one of my posts, I only drove it an hour at most with the ticking noise. Thanks in advance I really want to get my z28 running it’s been months.
How many miles on the cam? I would at least inspect it so it can be blamed/eliminated for the lifter issue.
If you do swap the cam put in a new cam retainer plate. They DO wear.
