Main clearance question with oil pump
7875 vs racing
forged bottom end
shooting for 700 tire -
stock polished 5.3 crank
got my block back from machinists
shooting for .0025 - .0030 main gap
will my melling high pressure oil pump work well for this application? Seems to have been quite the topic in regards to many guys running a high volume with good results.
so my curiousity piques myself if anyone has any knowledge of sorts . Thank you
I run the standard volume high pressure, i have an oil cooler, 10w40 .0026 clearance , 40psi at hot idle
For the OP, I think you would be okay with a stock volume pump but a 10296 wouldn't be a bad idea either IMO. I have a turbocharged iron 4.8L that I built with bearing clearances at .0022-.0025". With the stock volume pump and stock f-body pan, I'm around 20psi at a hot idle, but with load and RPM, it gets up around 40-50psi. Drifting will likely get the oil temps hotter and slosh the oil around in the pan a lot, so I think a 10296 pump paired with a good baffled pan will be a better setup. .
LOL, have you been watching Hoonigan's engine building videos? Guilty! No I actually read that somewhere and can't remember where but it said that you needed at least three.
