2002 6.0 swap
Old Jul 10, 2021 | 04:00 PM
mitchelc's Avatar
Default 2002 6.0 swap
Hello all, I swapped a 6.0 into a 2002 Yukon. It runs well, ish. I had a tune done, and it keeps throwing p0324, and is stalling and shutting fuel off (can’t start it back up) could this be something I did or? I swapped the cam sensors twice and cleaned the connectors and I have 12v. Thanks!
Old Jul 10, 2021 | 05:30 PM
dixiebandit69's Avatar
Check the connector for pushed in or loose pins.
I know that's gonna be kinda difficult, based on where the cam sensor is, but I've seen it before.
If there's any damaged pins, replace the connector.
Old Jul 10, 2021 | 05:34 PM
mitchelc's Avatar
I checked it briefly, looks a little dirty and weird but I’ll clean em up! It is getting 12v, and when I unplug it, it doesn’t run period so that tells me it works, but who says it’s sending the right signal…
Old Jul 11, 2021 | 05:30 AM
88bruce's Avatar
P0324 is a knock sensor code. You're changing the cam sensor based on that code?
Old Jul 12, 2021 | 08:16 AM
shakenfake's Avatar
I was about to say I think that is the wrong code lol
