C5 Corvette LS1 - plug #3 fouled?
Motor has ~95k on it. About 7k since cam swap.
Car has TSP Torquer V4, long tubes, stock 241 heads, regular LS1 PCV system, and no catch can.
At a recent track day, a buddy told me the car was smoking. He said it was gray smoke.
I pulled the plugs to take a look and this is what I found: https://imgur.com/a/lYgXLeO
I'm thinking maybe the valve seals on that cylinder? I replaced them when I did the springs. One other buddy suggested swapping the fuel injector from #3 to another cylinder and seeing if the darkness follows it.
Suggestions and insight welcome.
Seems odd to have rings go bad on one cylinder though, right? I suppose anything can happen though.
I used those one piece valve seals that came with the TSP cam, if that matters.
Swapped the injector from #3 over to #2 and vice versa. Put a new plug in #3.
Drove it to work and back yesterday. Checked the plugs this morning since I'm off.
#3 is good:
And #2 is not:
I wouldn't have even considered that. New one on the way - and of course, since nothing ever goes to plan, I broke a plug wire, so a new set of those is on order, too.
