Talk about some messed up stuff
quote: I asked Mike some very specific questions abotu what the plugs looked like and from his answers I didnt' need any PCM info to say they were not only running this motor but were pounding the **** out of it with a very unsafe tune in it. Guys he said he couldn't even SEE the white ceramic anymore on the plugs, they were black..not just speckled, but black... we all know what that means. un-quote
I don't remember all that well but I'm guessing a hydro lock?
The advice about "Moving on" probably says it best ... Learn... & do over!
-BT,DT
I know this is sensitive stuff cause of a potential lawsuit and all...but come on! This would make a good movie.
Seriously though, sorry about your bad luck. You haven't mentioned anything about your ex since your first post, so at least she's off your mind.
Good luck with everything and PLEASE let all of us know what happens.
Personally I'd prefer .080" intake .100" exhaust if possible. Clay is not accurate enough to check when you get that tight either, use a solid or shimmed lifter, adj pushrod and a dial indicator. I wouldn't trust clay in any increment below .100" at all.1998redcoupe, what was the free drop on those heads and the free drop on the engine with the right gasket torqued down around 10 degrees before or after TDC and at TDC? What was the lobe lift also at this point +/- 10 degrees before/after TDC as degreed in your engine and your rocker ratio? Or did the P to V get checked with a solid setup at the right place with the real springs and a dial indicator? How was P to V actually checked? I see this sort of thing all the time.
As Joseph said quite a few of these bigger popular cams are REALLY CLOSE even with stock heads and in fact some are crazy close and people just don't know usually, especially with milled heads or with bigger valves when still running stock pistons! We've pushed it before with some cams but we know we're playing with fire sometimes and some people are cool with risking that and can handle it if it causes problems.
