Need Thrust Bearing Help
Thanks again sir!
When you push the converter towards the flex plate all the way, do the converter pads contact the flex plate?
Its an issue if it doesn’t.
Are you using washers to get that clearance to 3/16?
If it started making metal that fast, I doubt it’s a ballooning issue.
Have you measured line pressure in the trans? Or cooler line pressure?
Excess pressure in the converter will push it forward. Common problem with T400’s, not sure about 4L60’s.
also once something sheds metal, even if it stops it going to be spitting the shrapnel out for a while..
The Clevite’s I have are H series.
They have 3 oil drain slots on the thrust (rear) side vs 2 on the front side.
Of course the block side has the oil groove. As well as locating tangs, so would not go in the wrong way.
If seeing more metal in the oil, its easy to check thrust clearance in the csr.
After the crankshaft is installed with the thrust main only hand tightened, tap the crankshaft fore/aft.
Now measure End Float, my "spec" is .008"-.012".
