Wtf is this awful noise? (Video)
Hey, I believe I made a thread about this a long time ago but never solved the case and didnt link any audio. The engine has 116k miles and started doing this after over-revving due to a misshift at high RPM (3rd to 2nd...). This was over a year ago and at first it only ever did it when cold so I figured maybe I just encouraged the well known piston slap to start early, but for a while now it's been doing it intermittently at idle even when fully warm. Never does it above around 1000 RPM. Pulled the valve covers and pushrods, replaced the pushrods just in case, but that didnt change anything. I've stupidly been daily driving it this whole time and performance doesnt seem to be affected though I'm not good at judging these things. Did a cold compression test and all cylinders are about the same with minor differences. Lifter, piston? Thanks in advance:
It still does it with the clutch pushed in, yes. I would be surprised if it wasn't an internal issue though, the sound increases in speed with RPM until it goes away after 1000ish rpm. I guess it is possible the cause was always present but maybe I destroyed the motor mounts when I over revved it. The sound is much more noticeable from the interior and I do feel a vibration when it occurs.
Check all pulleys. Remove the belts and check the pulleys. You could run the engine for a few seconds without the belts to see if the noise changes or isn't there. Possibly bad harmonic balancer
You say it sounds loudest around the drivers side head. Does it sound internal or external? I can't think of much internally that would make a noise like that and be intermittent. My lifters tapped a lot before I tore my motor down, but that was because they had 170k on them.
