Detonation
Old Jan 10, 2022 | 05:37 PM
corvet786c's Avatar
Originally Posted by Old Buzzard
Your log is showing a commanded afr of 14.08. The AEM says 15.8??
And right after that spike it knocks.
Plus that AFR is right off idle so it going to be up its not WOT.
Old Jan 11, 2022 | 07:22 AM
mikedamageinc's Avatar
Originally Posted by G Atsma
Check your exhaust. A hole will allow air in, telling the O2 it is running lean, thereby the O2 calls for more fuel, not less.
Could a hole in the header and too much fuel put a hole in a piston if running high rpms?
Old Jan 11, 2022 | 02:50 PM
Old Buzzard's Avatar
I understand that. I can read.
Old Jan 14, 2022 | 01:25 PM
corvet786c's Avatar
Hey guys, I am still trying to diagnosis this, Just scanned and got 2 degrees of knock, but it is just spikes of knock retard then imediatly falls. I think I know what it could be.
I installed hinson motor mounts, I wanted stock height but for some reason they were are lil taller, dont know why, but the intake is right up against the firewall, would this cause false knock, There is absolutly no room between the intake and cowel(fire wall). Thoughts would be great.Suggestions?
Old Jan 14, 2022 | 01:39 PM
corvet786c's Avatar
This graph shows barley off idle and I am getting knock spike, The engine is not under load, would indicate to me that its false knock, you guys agree, Please help!!!
ok so looking at everyone of my graphs, the knock starts off idle to acceleration. Something is hitting something or rubbing, I think my motor mounts are too high up, Do you guys agree????
Old Jan 14, 2022 | 01:40 PM
corvet786c's Avatar
This graph shows going WOT and no Knock, any ideas Thanks
