2001 z28 build
BTR CAMSHAFT - LS1/LS2 - N/A STAGE 2 32734132
Specs: 227/234 .614"/.576" 113+2
PRC Stage 2.5 LS6 CNC Ported Heads 2.02”/1.575” 59cc .660” lift dual spring kit
Bosch 42lb injectors
Monster Twin Disc Clutch
LT headers, OR Y pipe, Magnaflow cat back(looking to change this)
Curious of what kind of power the car makes with this setup. Trying to decide if I should upgrade from the stock ls6 intake and TB. I’m already looking into a GM 12 bolt with 3.73 gears. Thanks.
IMO it's worth it to upgrade from the stock LS6 intake to a Fast 92 or 102 and a larger throttle body. Your setup would probably pick up between 15-20 hp.
Stock LS6 with same heads, intake and tiny stock camshaft was rated at 400 fwhp (flywheel) from factory.
Ported 59cc heads 243s will give a solid bump in compression.
That said, I’d be concerned for piston to valve clearance.
This is 420whp all day on chassis dyno.
Lots of people throwing numbers out.
So let's get some details and info.
First terminology fwhp vs whp, rwhp two different worlds or engine Dyno vs chassis Dyno
Engine Dyno: fwhp
Engine on a Dyno with no accessories, real open exhaust with no restriction - HP equals maximum engine output in a perfect environment.
still subject to temperature and humidity day of Dyno testing.
Chassis Dyno: whp (applies to front wheel and rear wheel drive also AWD)
Engine in car with accessories ie: water pump, alternator, power steering, transmission, driveline, rear end or transaxle, tires, tire pressure and other variables ( but if equipped with K&N filter pleas add 20 HP) not all cars will have all listed accessories.
What matters is the Chassis Dyno those are real world numbers. People have a % loss calculation for engine to chassis Dyno too many variables to be reliable.
Then we have the "happy Dyno" and the Dyno operator.
After you spend $3000 to $5000 or more on your build. you better get the results proimised or the shop is going to get bitched out!!!
Environment makes a big difference - My car was Dyno'ed in December in Phoenix AZ - much cooler air then in July I probably gain 30 to 40 HP in the winter months due to Air intake temperature.
My guess is you will make about 380 rwhp with your setup.
Best bang for the buck would be going to a 3.73 rear gearing.
In the end, too many variables, shouldn’t speculate about power output.
FWIW - with a mere 224/224 cam & TEA S2 5.3 heads my 99 T/A made 418whp on a DynoJet way back in 2002. Same DynoJet several NASCAR teams used. There was absolutely no question to the credibility of the results.
With more cam and LS6 heads, it's very like the OP's combo will make at least 420whp like Cino mentioned.
My guess is ~430whp.
IMHO - these days the BTR above is a medium sized cam for an LS1. Typically, an LS1's torque curve will start to shift to the right when the intake duration goes above ~227-228 degrees.
To me BIG cams for the LS1 are ones like these famous named cams. Of course a cam doesn't need a fancy name to be a big duration cam.
1) Tick Performance Polluter V1 Classic Camshaft for LS1 & LS6 Engines242/244 | .61x”/.61x” | LSA112
2) TSP Magic Stick (MS4) 238/242 .600/.600
3) Thunder Racing T-ReX v.2 - 242/248 - .608/.612 - 110 lsa
It's somewhat subjective, depends on the quality of tuning and personal tolerance. Here my view, others will say otherwise etc.
