4.8 supercharged
Old Dec 25, 2021 | 05:03 PM
C1066's Avatar
Default 4.8 supercharged
Hey all have a stock 4.8 with a .600 cam 706 heads long tube headers thinking of a v-7 supercharger what kinda numbers would I be look at
like to later on make it a 383
Old Dec 26, 2021 | 09:45 AM
Ls1Rx-7's Avatar
A supercharger is a waste of time on such a small displacement engine. Look up Richard Holdener on youtube and watch his supercharger vs turbo video. I have a stroked 5.3 with a procharger f1a and i wish i went with an ls3 or turbo instead.
Old Dec 26, 2021 | 01:54 PM
C1066's Avatar
What kinda power u at with ur set up..
iv seen some where that the 4.8 do good on boost where there a short stroke and rev higher but idk…
I was wanting to do the supercharger arp bolts and a set of dome pistons and diff pulleys like to see 5 to 6 to the wheels but might not happen…
I have a ls3 block but it’s been bored out to 4.105 and idk about it be a nice n/a build but hate to put money into it an blow a piston out of it
Old Dec 26, 2021 | 02:32 PM
99 Black Bird T/A's Avatar
650hp 4.8 Turbo
I'd imagine, one could make similar hp or more with a supercharger. Probably make even more with turbochargers.
Old Dec 26, 2021 | 02:54 PM
AwesomeAuto's Avatar
I've made 600 to the wheels on 3 different 4.8s now on stock long block with cam/springs and cheap china turbos.
Turbo is definitely the way to go on a 4.8.
Old Dec 26, 2021 | 04:09 PM
C1066's Avatar
How much boost was u running and single or twine I’m not agent’s a turbo it would be cheaper it looks like just really ain’t done much research on them
Old Dec 26, 2021 | 07:53 PM
Ls1Rx-7's Avatar
This is a 5.3 with forged pistons, rods, 4” forged crank, tick blower cam, procharger F1-a, cnc’d afr 205’s on 11lbs and pump gas. This is through a T56 magnum and ford 8.8 irs. Tuner could only run it to 6,000 because the boost was gonna go to 13-15lbs and that was too much for pump.
Old Dec 27, 2021 | 10:53 AM
C1066's Avatar
sounds like a nice set up good # too I can see what ur talking about on wishing u when with a turbo tho still like them tq # down low tho
Old Dec 27, 2021 | 11:02 AM
C1066's Avatar
Well I’m stating to like the sound of turbo looks to be better and cheaper for the most part plus I found a nice looking kit that fits my truck y’all got any thoughts on it
https://www.cxracing.com/TRB-KIT-LS-...rch=C10&page=2
Old Dec 27, 2021 | 12:47 PM
pdxmotorhead's Avatar
Whats your power goal?
Do you need duals or would a single work.. ??
Old Dec 27, 2021 | 01:12 PM
C1066's Avatar
goal was 5 to 6 to the wheels but considering the v-7 supercharger was going to run me over 6k an this kit will run me around 4k I’d like to see more but with this kit it’s made to fit good and more for later on I hope
Old Dec 28, 2021 | 11:19 AM
I would avoid the CX racing kit like the plague and get something from Huron Speed.
Single, Twin, and Quad turbo setups.
To make 600 at the wheels, the single was on 13 PSI, twins were on 15 PSI, and quads were on 11 PSI.
All on stock 4.8s with just a cam at this power level. Some of them went must more extreme afterwards.
The single setup went high 8s at 29 PSI.
The twin setup went mid 10s at 3500 lbs with a T56 at 15 PSI.
The quad setup went 5.80s in the 1/8th at 15 PSI with a poor 1.40 60'.
Old Jan 1, 2022 | 09:08 AM
C1066's Avatar
how long did the single set up last on a stock 4.8 just wondering if I should upgrade anything on the motor I found a 78/75 turbo set up that I think will fit good
Old Jan 4, 2022 | 09:50 AM
The single setup is still together.
