6.0 ls top end help
Old Jan 4, 2022 | 02:09 PM
colekenny1's Avatar
Default 6.0 ls top end help
I have a lq4 block with stock crank and forged piston and rods (Pro LS Piston and Rod Kit, 364 Cid., 4.000 bore, 3.622 stroke, 6.098 rod, 2cc Flat Top, 10.7:1 @ 65cc, 10.4:1 @ 70cc, File-Fit Rings). Also have efi system with 102mm intake and throttle body
What is going to be the best cam and heads to go with this bottom. This is my first performance build and can be very confusing to figure out what is best
thank you
Old Jan 4, 2022 | 02:41 PM
99 Black Bird T/A's Avatar
Really need more information: like intended use, NA, forced Induction, NOS, automatic, stall, gear or manual, gear plus car weight etc.
Without that information, a generic Jack of all Trades NA set up to get discussion going, I'd favor:
706/862 heads ported by TEA or TSP, ~58 cc chamber for 11.4 to 1 compression.
Pat G stage 2 custom LS1/LS2 camshaft
228/232 .629"/.615" 112LSA +4
Definitely can do more cam in light car w/gear etc.
Old Jan 4, 2022 | 03:59 PM
colekenny1's Avatar
I’m going to be using this as a street car. Keeping it N/A for a while.
it’s going into a iroc Camaro
thank you
Old Jan 4, 2022 | 04:04 PM
jlangley's Avatar
Which port type is the intake you have?
The combo blackbird suggested would be a nice street setup if your intake is cathedral.
Old Jan 4, 2022 | 04:20 PM
colekenny1's Avatar
The intake does have cathedral ports.
Old Jan 4, 2022 | 04:35 PM
colekenny1's Avatar
Going to keep n/a for a while. Guy at my work says to go aftermarket heads. But this is my first go round so Im taking any advice for what is best to go with my bottom end don’t want to spend 2k on heads for them to be over kill and not used to full potential
Old Jan 4, 2022 | 05:41 PM
Jake Wade's Avatar
Contact Sloppy Mechanic. He has just the camshaft for you. It's called "The Best Cam"
Old Jan 4, 2022 | 10:49 PM
CattleAc's Avatar
This is probably not gonna' help colekenny1... but it's still funny $hit.
Old Jan 5, 2022 | 11:12 AM
Jake Wade's Avatar
For those that may not know, He and Richard Holdener teamed up together and created a profile that they named “The best cam” after all the questions they receive asking just that.
219/225 110.5 + 1.5. .595/.595
Old Jan 5, 2022 | 11:47 AM
RedXray's Avatar
The I think one of these "might" be the best cam ever
Cam Motion LS3 Stage 1 210 218 552 535 115 110 1200-5200 smooth idle, excellent low end torque, Does not require stall speed torque converter
Lunati 21460700 212 223 530 549 112 108 1600-6200 Good idle, excellent low end torque and mid range HP
Crane 2019371 216 232 590 624 113+2
Cam Motion Titan 1 217 225 595 587 114 112 2000-6000 slight performance idle and improved power emphasis on midrange power and torque.
Lunati 21460701 217 228 549 566 112 108 1800-6400 Good high performance cam with lots of mid range torque and upper end HP. Fair Idle.
Cam Motion LS3 Stage 2 220 230 578 561 115 110 1600-5600 noticeable idle, good low end torque, (1800-2400 RPM stall) and rear end gear ratios definitely recommended.
Crane 2019381 220 236 590 624 113
BTR LS3 Stage I 3 Bolt Cam 221 228 609 571 112+2
Cam Motion Titan 2 222 230 595 587 113 110 2200-6200 slight performance idle and improved power on mid-range to upper mid-range power and torque. headers, high flow exhaust and increased stall speed torque converter.
Vengeance Racing VRSP-1 223 227 610 614 114+4 1600-6200 mild lope at idle while offering excellent drivability characteristics Power/torque from 1600 to 6200 RPM
Texas Speed Stage 1 Supercharged 223 231 629 629 115 112 mild lope at idle and excellent driving characteristics factory torque converter
Vengeance Racing VRSC-1 223 231 610 617 115+4 very nice increase in performance while maintaining excellent drivability. The VRSC-1 offers a mild lope at idle
Lunati 223 232 615 599 111
Cam Motion LS3 Stage 3 223 234 603 578 115 110 2000-6000 very noticeable idle , with a little loss in low end torque, (2200-2600 RPM stall) and rear end gear ratios
Vengeance Racing VRPD-1 223 239 610 623 118+4 1000-6800 mild lope at idle while offering excellent drivability characteristics Power/torque off idle to 6800rpm RPM
Texas Speed Stage 1 LS3 225 230 629 615 smallest off the shelf camshaft more power than the stock camshaft even below 2000 rpm!
BTR LS3 Stage II 3 Bolt Cam 225 238 612 585 113+3
Crane 2019391 226 240 624 624 114+5
Vengeance Racing VRTT-1 227 223 614 610 115+4 turbo applications while maintaining excellent street manners and offering a mild lope at idle
Texas Speed Stage 2 Supercharged 227 235 641 649 114 2400+ great mid duration camshaft for power applications from 2400rpm+
Vengeance Racing VRSP-2 227 235 614 621 115+4 noticeable lope at idle while offering excellent drivability characteristic 1800 to 6500 RPM
Cam Motion Titan 3 227 237 621 604 113 109.5 2800-6400 aggressive street performance light lope to the idle and strong midrange to upper RPM power. headers, high flow exhaust and increased stall speed torque converter, high flow intake systems and increased rear axle ratios.
Lunati 21460702 227 238 583 600 112 108 2200-6800 Great street & strip cam, needs engine and computer modifications. Rough Idle.
Texas Speed Stage 2 LS3 229 236 629 615 great mid duration camshaft for power applications from 2400rpm+. great all around camshaft with awesome peak hp & torque gains without giving up low end power
BTR LS3 Stage III 3 Bolt Cam 229 244 615 595 113+4
Texas Speed Stage 3 LS3 231 236 640 615 2200+ great larger duration camshaft for power applications from 2200rpm+. large duration camshaft over 80 peak hp gains with a radical idle some bucking bellow 1500 rpm.
Texas Speed Stage 3 Supercharged 231 239 640 624 115 112 3000+ aggressive camshaft from 3000+ RPM max-effort engines 2800 RPM or larger stall torque converters
Vengeance Racing VRPD-2 231 239 617 624 118+4 1000-6800 mild lope at idle while offering excellent drivability characteristics Power/torque off idle to 6800rpm RPM
Vengeance Racing VRSC-2 231 239 617 624 115+4 very nice increase in performance while maintaining good streetability. noticeable lope at idle
Cam Motion Titan King 232 242 621 604 113 109.5 3500-6700 maximum effort street or street/strip cars heavy lope at idle and explosive power in a vehicle equipped with the proper high stall torque converter, rear axle ratio and supporting intake and exhaust
BTR Single Bolt LS3 Stg IV Cam 233 250 619 595 113+5 maximum effort camshaft acceptable piston to valve clearance
BTR LS3 Stage IV 3 Bolt Cam 233 250 619 595 113+5
Vengeance Racing VRTT-2 235 231 621 617 115+3 turbo applications noticeable lope at idle
Texas Speed Stage 4 LS3 235 239 627 624 more power than the popular 231/236 camshaft while still maintaining good p/v clearance some bucking bellow 1500 rpm stall converter 2800rpm or larger required.
Vengeance Racing KAOTIK 235 243 621 624 113+2 extremely aggressive lope at idle and excellent power/torque across the RPM range
Vengeance Racing VRSP-3 239 247 624 624 114+4 2200-6600 extremely aggressive lope at idle and excellent power/torque from 2200 to 6600 RPM.
Vengeance Racing VRSP-4 247 251 624 624 113+4 2500-6900 extremely aggressive lope at idle and excellent power/torque from 2500 to 6900 RPM
Old Jan 5, 2022 | 11:56 AM
RedXray- You pull an all-nighter doing the above?? Nice work!
Also shows why custom grinds are usually unnecessary with the variety on the shelf already.
Old Jan 5, 2022 | 06:34 PM
IROC - sweet! Big 3rd Gen fan here.. please post a picture(s)
A nice working "budget" solution old school LS1 set up is a set of stock LS6/243/799 heads with good valve springs like BTR Platinum or similar plus a 231/236 sized cam on 114. It will make similar power to a 224/228 cam'd engine with decent ported stock heads but it won't drive quite as nicely.
AFR also has an LS6 style replacement aftermarket stock replacement head called an AFR 210 ~$1,100. They'd be like new out of the box stock LS6/243/799. They should work well with a similar type cam.
Personally, I like ported stock heads & medium sized cam vs big cams & stock heads. Both work well but usually medium cam deals are easier to daily and enjoy.
Old Jan 6, 2022 | 05:52 AM
Rancherlee's Avatar
Sounds like you might be doing something close to what I'm building for my Chevelle. I'm putting a 4L80E with ~2800 stall behind mine and MIGHT boost it down the road so I tossed in forged rods/flattops. I just got my 317's back with a fresh PRC stage 1 job I've kinda narrowed my choices down to the Summit stage 1 turbo cam (aka Ghost cam) or a Sloppy 1.5/2 cam. The new Sloppy "best" looks good too.
