LS1 PTV 243 milled .30
i was wanting to throw on some 243 milled over will i have to go with shorter pushrods for good PTV clearance or will i be alright also anything else i need to know it’s my first engine build sorry
I'm not sure what your build goals are but that much duration and overlap is only going to run properly with very extensive supporting mods and a very very well though out complete setup. (Intake, fueling, and exhaust as well as the entire drivetrain need to be considered to get the most out of it and it's not something you can do one part at a time) Even still there will likely be drivability issues that you will have to life with in an optimized setup with that much overlap.
