Rebuild Book Recommendation
I’m an old school SBC guy and this is my first foray into an LS. Since is has 300k miles on it, I’m planning a full rebuild and build up, with the goal of 500-600 hp at the crank.
To begin preparing, can anyone recommend a comprehensive book on rebuilding an LS? I checked Amazon and there are lots to choose from! I’m looking for a technical bookthat that will help build a strong and reliable engine, not a “hot rod” book full of marketing. Thanks!
I used these two books when I rebuilt my L96 for my 1965 Oldsmobile Cutlass
How to Build and Modify GM LS-Series Engines and
How to Rebuild GM LS-Series Engines Book by Chris Werner
I used these two books when I rebuilt my L96 for my 1965 Oldsmobile Cutlassl
Then use that same search terminology to go down the line, Camshaft, Transmission, Cylinder Heads, etc. you would be amazed at how fast you can learn about all this stuff, and like you said, you want to learn facts, not hot rod marketing nonsense, which this place has in spades, a bunch of do it yourself type guys aren't going to sell you on a bunch of hyped BS.
Be sure and check out the LSx conversion forums, there so many cool build threads in there, you'll absolutely be able to find one on your Chevelle. In fact, here's a link to a complete video how to step by step in a Chevelle. Here's an overview of it.
good luck! study up and ask away.
Thanks,
Eric
you'll emerge from the rabbit hole a fully formed LS wizard.
Thanks,
Eric
There are a lot of us A-body swappers on her so don't be afraid to ask questions.
OP below is the engine manual for the LQ4 in PDF.
Spec wise it's very comprehensible, it's my go to when assembling an LS.
