LS6 Oil pressure issue - loss over time
How important is it for you to save the cam?
I'd commit violence on that cam bearing from the inside (use a square-ended carbide burr to cut a groove in it, and then chisel it out), but I don't know how much that cam is worth, or if it's even still good.
I've been in a similar situation before, but on an iron block; I just use a prybar to separate the cam from the bearing.
My comment was based on a cost/benefit theory that he could get a more or less good to go junkyard motor for less cost than the labor associated with fixing whatever is wrong with this one.
I ended up buying the cheapest aftermarket cam bearings I could find,and turned down one of the position 1/5 bearings to make a slip fit. Tapped it out towards the back, then cut the bearing and opened it up to remove from the cam. Because the bearing wore in at an angle, a ridge formed on the running surface that would not allow me the pass it over the cam, hence the cutting/opening up. Fortunately, the cam journals are fine. I'm in the process of measuring the cam bearing bores and so far they're withing factory tolerances.
On a side note - the cam bearings in positions 2, 3, and 4 were all positioned too far back in the bore. They were all such that the oil feed hole was exactly covered by the bore halfway. I seriously doubt they all walked backwards the exact same amount, so I'm chalking all this up to improper installation by the machine shop the previous owner used. :/
