Barbell popped out
Old Feb 27, 2022 | 11:10 PM
In post #13 he says 42psi at hot idle.
Old Feb 28, 2022 | 12:35 AM
saccitycorvette's Avatar
LS1Tech Sponsor
I had the pan and rear cover off to repair the damage to my pan after landing from a wheel stand.
I noticed the barbell was popped out. So up against the rear cover as it can only go so far.
Had this thing apart several times, but haven’t seen that before.
Two changes since last time apart. Melling 10296 pump with the high pressure spring and the Sac City barbell.
So I’m thinking simply a lot of oil pressure? Maybe too much. It’s 80+ going down track. Maybe more. I don’t have time to look at it. Gauge is to low to see easily.
Cant be helping the passage alignment with it not seated.
Anyone else ever see this?
The barbell fits nice and tight.
Thinking while it’s out, I might put the std pressure spring in.
Ron
Hi Ron,
Its normal for the Barbell to get pushed out against the cover from the oil pressure. The barbell is designed to sit around .050" (gasket thickness) out of the block.
Thanks
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
Old Feb 28, 2022 | 08:15 AM
Darth_V8r's Avatar
Moderator
Originally Posted by saccitycorvette
Hi Ron,
Thanks
Christian
Thank you.
There is a reason that hole is recessed into the cover.
Old Feb 28, 2022 | 08:56 AM
wannafbody's Avatar
I'm referring to post 12. Isn't oil pressure supposed to increase 10 psi per 1000 rpm?
Old Feb 28, 2022 | 10:32 AM
At the pressures being discussed here, that would depend on the relief spring cracking pressure.
If starting at 75psi at idle, it wouldn't take much revving to hit the relief pressure threshold.
Old Feb 28, 2022 | 12:37 PM
RonSSNova's Avatar
Well, I gather it’s a moot point. It’s designed to pop out and hit the cover.
Back to trying to fix this pan, which is not going well. Price jumped from the $350 or so I paid for it a bit over a year ago to $440. Ouch.
Appreciate all the comments.
Ron
Old Feb 28, 2022 | 02:44 PM
LS1Tech Sponsor
Hi Everyone,
The Barbell is designed to be pushed out from the oil pressure around .050". At that point the the O ring is sitting approximately center in the block
to insure a good seal and the rest of the barbell is set to where it is not blocking the oil ports. Pushing the barbell further in can cause interference with oil passage
and the O ring will not be centered in the block.
Hope that helps clear up why the Barbell sticks out a little. BTW even the factory Barbell stick out.
Thank you,
Christian
__________________
Old May 25, 2022 | 03:43 PM
LS1Tech Sponsor
Hi Everyone!
We have the Billet Barbell and other Billet oil System improvement parts ready to ship, along with the AlignIt Tools if you need them.
https://www.saccitycorvette.com/OilS...provement.html
https://www.saccitycorvette.com/AlignItTools.html
Thank you
Christian
__________________
Old May 25, 2022 | 04:34 PM
LLLosingit's Avatar
Edit: My comment was already covered...so no need to go over it again.
