Should I gap my rings when going Single Turbo?
You are discounting the fact that many people have run more boost than he plans without ever touching a ring gap. I have seen low boost motors run 200k+ miles without ever having the internals opened. I have also seen people with too much ambition and not enough sense spew oil on their very first track run.
A large amt. of boost for a few seconds and low boost for a long pull can both break ring lands.
That's why if you play it safe you WILL file the rings for more gap. If not, you take a big chance at breakage.
There is no magic formula or equation here.
It's not about how much boost it will hold, it's about heat load on the rings.
Alright
I always subscribe to the idea that if my ambition exceeds my current hard parts, I can plan a new rebuild on the ride home in the tow truck. Why rebuild a motor before it blows? Besides, most newby stuff also involves tuning errors. Best to get them out of the way before buying expensive stuff. Save the fully forged badass motor for after you work out most of the kinks.
More people have screwed up a perfectly good running sbe by pulling them apart to gap rings and switch to arp rod bolts than have hurt them with low boost.
I say run it as is and if you switch to e85 the stock ring gap becomes even less of an issue. I'd run e85 or meth before I'd pull apart a good running engine just to gap the rings.
Too many people think things they've never done have to be done a certain way.
Good tuner goes a long way. E85 changed the game a lot also you can run way more boost on E85 with a good tune before stock ring gaps become a problem. That higher latent heat of vaporization is huge for cooling the combustion chamber...rings therefore don't get as hot or expand as much...thus larger ring gaps aren't needed. As you see many many people running big boost numbers on sbe without the rings gapped on E85 and being very successful.
