LS1 Machine Shop Questions
I also tried looking up the numbers on the block but had no luck finding any information. are there any physical details or maybe a set of numbers I am missing to show me on what I can do with this block?
it does not have any displacement numbers in the usual spot I've know to look for,
I plan on starting with just the short block currently then will work on finding a set of heads for my goals. (if I have to switch the heads when I add boost I will)
this build is not in any rush, and i am not willing to swap the block as i already have the LS1 block laying around
Goals
chassis is a 350z 6mt which is mostly for Autox, doesn't need to be "streetable'
- 4in stroke
- Above average NA power~500whp,
- would like to supercharge down the road for no more than 650~whp
- camshaft can also be switched for boost
Edit - wrote by book, while pics were posted lol
Aluminum block LS1/LS6 bore & stroke
97-98 LS1 blocks a hone for clean up ~.005
99+ LS1/LS6 Improved liner positioning in 1999-and later 5.7L LS1 blocks and all LS6 blocks permit boring up to 0.010-inch oversize.
3.903 to 3.905 being typical
Long ago sleeving an LS1/LS6 block was an option for bigger bores up to an absolute max of 4.200 with 4.185 allowing a rebuild. Newer LS2/LS3/5.3 blocks are used now and sleeving LS1/LS6 is 🚫
Stroke - some that don't know how to correctly select pistons or do math will say ~3.9 is max stroke for an LS1/LS6 without oil consumption issues and pistons skirt wobble due to the length of the cylinder sleeve. However, 4 inch stroke works very well no issues with a competent engine builder who selects the correct taper pistons like Wiseco, JE, Summit etc all offer. Expect ~50,000 to 60,000 miles before a rering/refresh is needed with 4 inch stroke. Might go longer with good maintenance & oil changes might not. If you want a 300,000 miles or 8,000 rpms out of your LS - keep the stock stroke.
So a ~ LS1/LS6/punched 5.3 with 3.903 bore & 4 inch stroke makes for 383 cubic inches.
Regarding stroker cranks...pick your engine builder and discuss with the builder before buying. Some shops will want you to use their house favorite and not want to use anything else. Quality make the the same but if the build has preferences for XYZ - do yourself a favorite and use what the builder likes.
Center Counterweighted LS Crankshafts are the better choice for LS stroker cranks and only cost a few hundred dollars more. This style makes for a more ridged crank that isn't as hard on #2 & #4 bearings based on what a reputable engine builder shared.
Callies Compstar Center Counterweighted LS Crankshaft is one example. I think Callies was first to offer at at reasonable cost to the masses.
Borowski Race Engines, says we like to use fully counterweighted crankshafts in our engine builds. We believe the additional cost of 8 versus 6 counterweights is more than offset by the value delivered in engine longevity and performance. This design increases the stiffness of the crankshaft and reduces harmonics. The direct result is reduced flexing of the crank. The indirect results are greatly improved bearing life and a much stronger bottom end, particularly with a GM LS block.
Both of my LS strokers 383 & 416 have the older standard 6 counterweighted Callies CompStar cranks and no issues but the newer CCW is the smarter choice now that's its available.
Regarding Forced Induction, running a belt driven supercharger is very hard on the crank snout and #1 bearing. CompStar's are usually good to ~800whp with belt driven forced inductionfrom what I read, over that level sometimes the snout of the crank can snap or crack. If big Procharger power might be in the future a Magnum or DragonSlayer level of quality should probably be used. Same idea applies to all the various levels of cranks available from various manufacturers. (Just using Callies CompStar as example as I have those in my cars and am more familiar with them)
Improved Racing just released a 4 inch crank scrapper & windage trays! No more washer spacing etc. I'd definitely suggest checking out the IR parts.
Harmonics are a big deal so I'd suggest a Fluiddamper or ATI Superdampener. I have a 10% UD ATI on my 416.
Engine #'s
1998.......12550592,12559846,12559090
1999.......12550592,12559846
2000.......12559378,12559846, 12560626
2001.......12559378,12561168(Corvette/some lucky Camaro/Firebirds)
2002.......same as 2001 (service part# 12561166 2001-2004 LS1/LS6)
Edited - list above isn't complete, example
1999 - LS1 pulled from my 99 T/A
Please see revised post. Found what I think is more accurate break down of part numbers.
That's good to know!
I was about to list a virgin 20 year old, NOS LS6 block in marketplace for $250 but will keep for a while longer now. May take a few more years but will make a 427 out of that LS6 block yet!
You list an LS6 block for $250, and you'll need unlimited data on your phone, and probably need a new phone within 4 months!!!!!
