Pushrod measuring opinion
Personally I don't like the "method" of counting turns on the rocker bolt to "measure" anything. Just seems kinda crude, at best. Esp when you have an adj PR in your hand. That "alternative" is for people who don't have the tools. You don't need it. Ignore it.
LS7 want about .080" of preload. If your adj PR produces zero lash at 7.425" then 7.50" PRs will give you .075". Close enough for gummint work, for sure.
The differing methods of measuring, gauge length vs end to end length is approx .015". Not enough to make or break preload.
Most basic LS builds fall between 7.375 and 7.425". But we always check to be sure.
Counting turns is simply confusing......
https://gwatneyperformance.com/lifte...ont-hurt-will/
and towards the bottom they are indicating that as little as 3/4 of a turn will suffice for lifter pre-load.... Hmm... makes me wonder if I've just been using the wrong length push rods and setting them up for too much pre-load all this time. I may have to try the 3/4 to 1 turn method on my next build... as luck would have it, I will be building a .030" over 6.0L next week... I'll go for minimal pre-load and see if I can get it a little quieter. Worse case I have to change them out after its installed in the vehicle.
and before I forget.. I really enjoy everyone sharing what they know, or what they believe to be true... I hope that everyone that has experience with this that comes across this thread will share their experiences. somewhere within all the personal experience(s) we will find the best way to set this stuff up. For me, today, I learned that maybe 1.5 turns is not the optimal way to do this. I will start using the 3/4 to 1 turn from this point forward until I can factually state it's either better, or worse, and adjust from there. I'm really excited now to build this next engine next week to see how how much noise, or lack of noise, this next 6.0 makes.
