Ls1 wh blowing smoke
1) White smoke means coolant and usilally this means blown head gasket and coolant is making its way into the combustion chambers and into the crankcase which is very bad for bearings. (You will notice the oil looks milky almost like choclate milk if this is happening)
2.) Blue smoke means oil is getting into the combustion chambers and burning during ignition of air/fuel mixture. (You will notice oil deposits on the spark plug or plugs and this can be cause by several reasons. Poor PCV valve, worn valve stem seals, worn valves or seats and piston rings.
3.) Low oil pressure light is never a good sign and it might be time for an overhaul, however if it's the low oil level sensor then you might be low on oil.
During normal startup on cool mornings it is normal to see condensation or white steam coming from the exhaust and you will smell fuel but engine coolant does put off an awful odor so I'd investigate. Another sign of an issue with coolant getting into the combustion chamber is that you'll notice oil in the radiator.. Hope this helps!
