Anyone have similar h/c combo? 243 799 cnc 2.02 milled .020
So i picked up a set of built heads. Not from original owner. So had no clue who cnc'd them. But are 243. On face of heads stamped E011
They have 2.02/1.57 valves. My harbor freight mics measured from my unmilled 243 to these cnc heads, .023 so idk exact amount milled.
Now I'm running mild cam. The SDparts LS6 power max plus cam and factory mls head gaskets. So I'm thinking I should just order 7.374in pushrods. I was running with my factory 243 heads 7.4 cr-mo pr's. But being a mild cam and heads milled, I should still be ok with 7.4 pr's right?
Anyone with similar combo?
Thx in advance
Thx in advance
You should always measure especially given you know so little. I'd likely have a local shop deck the heads just enough for cleanup and check the spring pressure.
7.375 wouldn't surprise me but only one way to know. Lifter choice can also change length due to the height of the lifter and acceptable preload.
The following users liked this post:
Coy (03-29-2023)
Not 100% sure yet... But prob my 02 SLP UltraZ. I'm not touching the low mileage LS6 shortblock, but thinking boutz throwing these heads on the ole garage queen with a nice stg3 cam. And thinking having TPIS do the 90mm mod to my intake mani. These cnc'd 243's have to be close to prc 2.5 243 heads.
G Atsma (03-30-2023)
