Compression pump gas question
Thanks
I run 11.8:1 on my car, the Wallace Racing dynamic compression ratio calculator has me at 8.7 or 8.8 DCR. I've been running at sea level with 92 octane, no problems.
According to the Wallace Racing calculator, it looks like the static CR has to be 10.8 or so to keep the DCR under 8.7:1.
I'd suggest running a thinner (.040") head gasket and adding a few cc to the chambers. The thinner head gasket will improve quench, which helps prevent detonation.
Using the stock static CR of 10.2:1 for the LS1, I get 8.19:1 DCR.
