Spark plug stuck
So on my Camaro the #8 spark plug is stuck/cross threaded from previous owner. I tried to take it out years ago and it was giving the feeling of stripping the head threads so I left it, as I didn't have time to take the head off if it stripped.
The time has come that it has to come out this year.
So the question is, what is the best scenario to get it out without stripping the threads?
Engine cold
Engine hot
Engine cold
Engine hot
In theory if it's just stuck, I would try to take it off when it's warm.
If it's cross threaded it's not going to matter.
If it's seized and pulls the threads out with the spark plug you will have to pull the head.
If it's cross threaded you are going to have to pull the head.
Just found it, or a version of it, on Amazon!! Called a "Powerbuilt Back Tap!" $28.00. Best of luck......
