Much difference in these cams?
Old Mar 9, 2025 | 09:44 PM
68Formula's Avatar
Originally Posted by Abs
Summit pro ls cams are 49. I have never seen lower than that in an ls cam other than the howards asa and hot cams, but they are only .525 lift, so I think that's how they are able to do that. BTRs truck cams are 50 but again I think they only go that low because they are .550 lift. Their higher lift cams I'm pretty sure are 53ish. They test on a spintron to make sure valve control is not lost with their lobes. Once they see bounce or float occurring, they scale back.
You're referring to the difference between 0.006" lift and 0.050" lift which is a small portion of the cam lobe mostly influencing hertzian stresses on the opening side, and valve impact force on the closing side. There's a lot of lobe profile after 0.050" that plays into valvetrain stability. The intensity has very little influence.
Comp has many different LS lobes in their catalog with varying differences in lobe intensity much lower than 50* depending on design. Isky has some in the 48 range. I once saw one if the high 30s on the cam card, but it wasn't a vendor that advertises their .006" lift, so can't recall who it was.
Old Mar 9, 2025 | 09:57 PM
Abs's Avatar
Abs
yeah unfortunately we don't know much about the profile than .050 and sometimes .006. I know .020 is crucial too but we are often rarely given that. The .600 lift and 49 difference between advertised and .050 does make me concerned enough to seek something a bit less aggressive. Maybe that is unnecessary or unfounded or maybe not.
