Overheating with Meziere Water Pump
I have a Meziere electric water pump on a LS1 fbody that has been working fine for years, but this summer I started having an overheating problem. The car gets up to operating temp as normal, then after a minute or two of maintaining the proper temperature, the thermostat starts climbing rapidly. The pump seems to work because I can hear it when the engine is off and the key is in the run position. No signs of coolant leaks. Any ideas on what the problem could be?
Check the radiator for cold spots. Todays coolants contain silicates that easily stick and eventually after a lot of miles or a lot of time…whichever comes first…will clog a radiator in certain areas. Had this happen to me last summer with an Altima. Found the issue by using an infrared thermometer. About half the radiator was cold to the touch after locating this issue. Of course I threw a thermostat at it first….$$$
Fans work. I was out for a ride when I first noticed the problem, and it was overheating while the car was in motion. I thought it was low coolant at first but saw no signs of leaking anywhere, not even around the heads or sides of the engine. Does parking downhill on an inclined driveway have any effect on the cooling system, such as causing it to somehow get airlocked?
Are you running Dex-Cool? A good friend of mine worked for the largest radiator shop in this part of the state. He said the early stuff would coagulate into a jelly like substance if left in too many years. GM supposedly reformulated it years ago, and the newer stuff supposedly is good stuff. I use it. But I never let my coolant go over 4-5 years, 5 years absolutely the max. It works fine for me. I'm with Che70velle, probably the radiator. That or the T-stat...
"Lifetime," to GM, being the duration of the warranty period, which in those days was 3 years, 36,000 miles...
They pushed that same line of bullshit with transmission fluid, too. Remember when the "new" Malibus came out in '97.
I specifically remember the commercials saying that you would never need to change the transmission fluid, and that instantly tripped my bullshit detector.
Do you know how many 4T60 transmissions I've changed out because of failures that ultimately resulted from lack of maintenance? More than some guys, less than others, but it's been a few.
It's easy to blame inattentive owners, but you have to keep in mind that GM was marketing Dexcool as a "Lifetime" coolant.
Sounds like a radiator issue as mentioned above etc.
FWIW - Zerex G05 is 5 year/150,000 miles and holds up very well in my experience. Have seen radiators look cleaner with G05 after ~12 years than other coolants after a year.
