Exhaust valve clearance issues
Or, if you have dual springs, just install the inner spring only.
With valve reliefs like those, I wouldn’t expect PTV to be an issue. That cam isn’t big.
Adj pushrod to 0 lash on the base circle, rocker bolt tight just as KCS said.
My thoughts too, Ive ran bigger cams with no valve reliefs and not had issue on .045 head gasket and milled .010 heads
