180* lifter trays
Old Jul 19, 2022 | 01:58 PM
Josh higbee's Avatar
Default 180* lifter trays
Would lifter trays that are rotated 180 cause any issues. Already have the head bolted down and don’t want to take it apart if I don’t have to.
Old Jul 19, 2022 | 02:35 PM
RB04Av's Avatar
Pretty sure they are jammed up against the block and can't "float" on the lifters like they're supposed to.
I don't think they'll survive very long, and when (not "if") they fail, it's gonna cost you A SHIPLOAD M\ORE to fix what happens (turning sideways and EATING lobes and rollers), than a pair of HGs.
Old Jul 20, 2022 | 06:42 AM
SAPPER's Avatar
It'll be fine. The early blocks don't have locators anyway like Gen4 blocks. They are still the same dimension just with locators.
Old Jul 20, 2022 | 09:49 AM
grinder11's Avatar
This They are "central" IIRC, meaning they're reversible. However, years ago, some guys drilled 1/2" (?) diameter holes in one side of the trays, to aid oil drainback. If thats the case, they should go in however they came out. I cant remember if the holes faced inward, or outward.
Old Jul 21, 2022 | 06:45 AM
SAPPER's Avatar
They face outward. so as to allow the oil to drain downward. 1/2" is a little much. I drill about a 3/8" hole. I started doing this about 2004 and built many many engines using this method and never had an issue. It's so much cheaper than link bar lifters.
Old Jul 22, 2022 | 01:50 PM
grinder11's Avatar
The ones I have with 1/2" holes were modded by Kurt Urban or Billy Briggs when both were still at Wheel to Wheel. I never had a problem. I won't disagree with you, however, as you would think 3/8" would be large enough. Maybe in a roadrace app the 1/2" may have some advantage, so maybe that's why, IDK.......
