Windage tray 383 stroker?
Old Sep 10, 2022 | 09:37 AM
Rockitansky's Avatar
Question Windage tray 383 stroker?
I have an 02' Z06 with a 383 stroker that I road race. I don't have an accusump or dry oil system but would one of improved windage tray help with keeping oil in the bottom end so it dont run dry in heavy side G loads? THX all!
Old Sep 10, 2022 | 10:20 AM
Your not going to see a windage tray keep oil in the pan per say. A windage tray helps with unwanted oil going in a direction that causes oil to get whipped up or foam. Controlling windage in the crankcase (and under the valve covers, but that’s a different sermon) will free up power. What your looking for, going by your post is an oil pan baffle. The correct baffle setup in the pan will keep oil pooled at the pickup as best it can, therefore helping with oil control in high G situations. The C5Z has a unique pan configuration to start with, that helps keep oil in the right place during cornering. Improved Racing has developed, in my opinion, the best oil control products in the industry for guys like you. Give them a call and let them consult with you and your needs.
