LQ4 with different heads
Old Sep 20, 2022 | 07:33 PM
Nflynn671's Avatar
Default LQ4 with different heads
I have an LQ4 with 317 heads and a sloppy stage 2 cam, was considering buying some heads from u pull parts. Found some 862 and 799, and was favoring the 862’s, I plan on porting them and potentially milling them but was wondering if a higher compression ratio would be safe with a sloppy stage 2 cam or not.
Old Sep 21, 2022 | 10:08 AM
stockA4's Avatar
You can do flat top pistons and the 862 heads (11.5cr) with that cam and you will still be good to go
