Quiet cammed stalled truck
Old Sep 30, 2022 | 11:14 PM
Mikerockzee's Avatar
Default Quiet cammed stalled truck
I’ve got an 02 1500hd and Ive decided to replace the cam. I’m keeping stock exhaust from manifolds to tailpipe. I want a high(3000) stall converter because i think they’re fun to launch. Having the stall means I don’t really need to worry about bottom end power right? Any suggestions on a cam for me
Old Sep 30, 2022 | 11:27 PM
Are you daily driving the truck? Do you do any towing?
Old Sep 30, 2022 | 11:49 PM
No towing. I do daily drive it but in a small town with. No traffic. It will see road-trips though. I do have to sit and idle a lot but I’m doing that in my 7.3 right now so trying to keep it a bit quieter than that.
Old Oct 1, 2022 | 06:17 PM
I’d throw the stall converter in it first and see what you think. A 3k stall will change the way it drives a lot. That and gears will completely change the way the truck behaves. Before we discuss camshafts, are you interested in changing out valve springs also?
Old Oct 1, 2022 | 09:09 PM
I’ve got the engine out right now. Was leaking from rear main oil pan and multiple freeze plugs.
Old Oct 2, 2022 | 12:35 PM
LilJayV10's Avatar
If you know you will doing a cam, I'd do that first and then pick a convertor.
Spend the money on a good convertor like Circle D or such. It's definitely worth the extra money.
There are some things you can go cheap on when building a car. A convertor and injectors are not one of them, IMO and experience.
Old Oct 2, 2022 | 01:45 PM
Ok, didn’t know engine was out. What other mods are you doing here to compliment a camshaft change? Looks like your leaving the entire exhaust alone…intake? TB? You don’t want much camshaft if everything else is being left alone. It all has to work as a combination. Interesting about the leaking freeze plugs…I’ve yet to see an LS engine leak at the plugs.
Old Oct 3, 2022 | 01:30 PM
1FastBrick's Avatar
I have seen the plugs on the heads leak if you neglect the cooling system... I also have a pair in the scrap pile that ate away all the cooling passages from Erosion.
