Lifters Junk or Just Breaking In?
So after seeing the new ones and doing more research I'm leaning towards going with different lifter altogether but I'm not seeing many options that arent a "race" lifter. Whats everyone's recommendations for 799 heads, EPS cam .604 lift, cammotion duals 155lb seat psi / 400lb open psi, 6500 rpm max?
I would like something quiet and not something tight about preload. I was looking at the Luanti 72332 (which are Morel 5290 I believe) but heard they are very tight on preload tolerances, .030-.035. Plus, I dont like the tie bars and have seen some failures from them. Or maybe I should I just get another set of 7717's (from somewhere besides Summit). I've even been thinking about getting new springs in hopes of giving me more lifter options and possibly be quieter due to lower seat pressure, the duals are overkill but I like the safety of dual springs.
I checked the lifter bores with a telescoping gauge and came up with .8440 (give or take a thou or 2). With the Morel lifters being .8415-.8420 that gives me .0025-.0020. This is a little more than Morel wants (.0015-.0017). Do you guys think this is an issue? The stock ones measure right at .8422-.8420 (again, give or take a thou) and they didnt have any issues.
If you dont mind, what springs and lift cam, any chance you measured OD on lifter bodies? So many people have no issue with these and chances are slim you have my kind of luck. If it sounded good already you're probably in the clear. Just out of curiosity, did you get them from Summit?
My lifters came in a bag with some sort of heavy oil in it. WTF- LOL. I hope I don’t find any nicks or gouges in them
I’d call Summit back and change out those nicked lifters.
I'm going to send them all back to Summit. If I get 7717's they will be from another company. I think Tick has them for $210, but at this point I'm wondering if I shouldn't be going with a better lifter altogether. I wish I could find something like the 5209's without the tie bar.
Damn...so the cardboard packing is the step up..lol
