Oil Pan Gasket Replacement?
Old Jan 5, 2023 | 03:48 PM
wormw00d's Avatar
Default Oil Pan Gasket Replacement?
putting in a new cam and decided to replace the oil pump while i was at it, i cant for the life of me get the dreaded pick up tube bolt to go back in. i see people saying to unbolt the oil pan to gain about an inch of room. my question is, do you need to replace the oil pan gasket if you just unbolt the pan and let it hang?
Old Jan 5, 2023 | 04:00 PM
LS1 TJ's Avatar
I would give it a shot. Reuse the old pan gasket. I assume to replace the pan gasket would need to pull the engine? Make sure you add a bit of silicone at the corners that meet with the timing cover.
Old Jan 5, 2023 | 06:34 PM
jetech's Avatar
Veteran: Air Force
I twisted safety wire around the bolt head to help support it and keep it from falling in the pan. You can reuse the oil pan gasket
Old Jan 5, 2023 | 07:23 PM
wormw00d's Avatar
jetch, i tried that, with no luck, i decided to drop the oil pan, that worked, now i hope i dont get a leak.....
Old Jan 8, 2023 | 05:32 PM
grinder11's Avatar
I can't remember exactly, but iirc, I used a socket head cap screw, aka Allen bolt to hold the pump tube on. Yeah, it can get pretty poophole puckering with that screw!!! In a C5 Vette, dropping that into the pan would make a good day bad, real quick!!
Old Apr 5, 2023 | 08:47 PM
wormw00d's Avatar
Default Thank you
Thanks all, reused the gasket, no leaks
