Machined crank confusion.
Old Jan 29, 2023 | 02:16 PM
Ben16SS's Avatar
No problem and glad to help. Just throwing that out there about the mains so you could confirm you were reading the tool correctly.
thank you man. So just to be clear what bearings do I need to add .001 to the mains ? Undersize oversized I don’t understand the nomenclature. I also need to reduce my Rod bearing clearance by at least .001.
Old Jan 29, 2023 | 02:34 PM
01CamaroSSTx's Avatar
Well if the crank mics out to 2.099 on the rods and 2.558 you should be fine with Clevite P-Series standard bearings. What are your measurements for the rod and main bores? Having 0.025-0.030 clearance for an iron block build ran on 5W30 would be ideal IMO.
Old Jan 29, 2023 | 02:52 PM
Ben16SS's Avatar
So I had my gen 4 rods fitted with arp bolts and they honed them to true them. I have not measured the id of my rods with a snap gauge or anything I just installed my std bearing in the rods torqued them then measure with my bore gauge zeroed to the micrometer reading from the crank and was getting .0035 on the rods is t that too much?
Old Jan 29, 2023 | 03:07 PM
Have you taken measurements at different locations of the rod bore to make sure your gettting a consistent number? What bearings are you using? 0.0035 is on the loose side of things but I also don't think that's a bad thing either it just means you can run a thicker oil.
Old Jan 29, 2023 | 03:18 PM
Ben16SS's Avatar
yeah I took measurements in a few places on the Rod maybe about .0002 variation at most
these are the bearings
Old Jan 30, 2023 | 08:06 AM
grinder11's Avatar
I'm reading 2.09 somthing. Now look at the 1-9 numbers on the side to see what lines up with a line on the thimble screw.
Yes, you are correct. This is a LONG way from 2.0775"! 2.099" diameter should give only .001" clearance, which is too tight. OP-Where did the .0035" clearance # come from?
Old Jan 30, 2023 | 08:08 AM
Ben16SS's Avatar
i measured the Rod journal locked my mic the. Zeroed my bore gauge to the mic and checked my clearance on the Rod. And yeah I was definitely reading the mic wrong at first.
Old Jan 30, 2023 | 08:11 AM
grinder11's Avatar
Originally Posted by Ben16SS
I was thinking that after you pass one of the .025 lines you then add the next number on the thimble at .00xx and add them. So I was starting with 2.075 + .0024 then + .0001 for the line up of the finest graduation. Should I be adding .024 not .0024 is that what I’m goofing up?
YES. .024", NOT .0024". Each complete turn, 0-0, is .025" on an SAE mic. You are approximately .001" under 2.100", which =2.099".
Old Jan 30, 2023 | 08:15 AM
Ben16SS's Avatar
yeah 01camarosstx helped me figure out that fowl up. That was most definitely my bad.
Old Jan 30, 2023 | 08:19 AM
grinder11's Avatar
For a sanity check, just use a digital caliper. Reading a .0001” vernier micrometer can be confusing if you don’t use them all the time!
Getting accurate measurements to .0001” really takes the correct “feel”.
You're right, Ron. Reading 1 10,000" (100 millionths!!) is extremely difficult!! I was a T&D maker for over 40 years, and did this a LOT. OP-I don't care how good you get at using a mic, when you start trying to read "tenths" on a mic, best you can hope for is plus/minus one tenth, which is pretty damn accurate, except for aerospace, which is on another planet, literally!! Caliper will get you within a couple-three thousandths, then use the mic to get an exact number.
Old Jan 30, 2023 | 08:22 AM
Ben16SS's Avatar
Reading 1 10,000" (100 millionths!!) is extremely difficult!! I was a T&D maker for over 40 years, and did this a LOT. OP-I don't care how good you get at using a mic, when you start trying to read "tenths" on a mic, best you can hope for is plus/minus one tenth, which is pretty damn accurate, except for aerospace, whoch is on another planet, literally!!
yeah i totally get that. I’m just trying to use the right tools so i have the best chance at a quality engine at the end.
Old Jan 30, 2023 | 08:29 AM
  #32
grinder11's Avatar
What I don't understand is where the OP got .0035" clearance if the the crank is@2.099", and he's using standard bearings........
Old Jan 30, 2023 | 08:34 AM
  #33
grinder11's Avatar
I'm assuming you mean .0025-.0030 clearance, NOT .025-.030!!! This is where confusion enters the picture for inexperienced builders......
Old Jan 30, 2023 | 08:36 AM
  #34
Ben16SS's Avatar
I’m looking to be in the .0025 clearance range.
Old Jan 30, 2023 | 08:38 AM
  #35
grinder11's Avatar
I'm glad you're trying to do it the right way, with the right tools. Practice with that mic will make perfect with that mic...
Old Jan 30, 2023 | 08:41 AM
  #36
grinder11's Avatar
That would be just about as good as you'll get it.
Old Jan 30, 2023 | 08:43 AM
  #37
grinder11's Avatar
IIRC, aluminum blocks are set up about a half thou tighter (.0005) than iron blocks, due to greater thermal expansion of aluminum vs iron...
Old Jan 30, 2023 | 09:09 AM
  #38
LS1Formulation's Avatar
These bearings should work for your rods. They're designed for cracked cap rods that have been honed .002 over: https://www.competitionproducts.com/.../#.Y9fdL3bMLrc
Old Jan 30, 2023 | 09:32 AM
  #39
Yes I forgot a zero there.
0.0025-0.0030
Old Jan 30, 2023 | 10:23 AM
  #40
0.0025-0.0030
Hate when that happens.... LOL
