Machined crank confusion.
Well you know, I also have a 5.3 crank polished. The machine shop recommended this little shop and that's all the guy does there. I have not actually measured the crank journals or "mic'ed" it. 🤔
I'm assuming you are measuring with a dial bore guage the direct clearance? Can you get non-standard bearings to make your target clearance? You can mix-match different bearings to get there, but I don't recall what the rules are and you have to buy 2 sets.
I just rechecked zero and it’s perfect. Measured Rod journa #1 again and got 2.0775 unless I’m completely reading this wrong.
Getting accurate measurements to .0001” really takes the correct “feel”.
