Safe DCR for 87? Forged pistons?
To do so I have a few questions
Will bumping up Static compression ratio make up for using a cam with a larger LSA? (like it will still have similar low end torque? will the larger LSA Rev higher even though DCR is the same?)
What's considered a safe DCR for 87 pump?
Guy I bought my heads from had a similar build he said he had 10.6:1 with a 112 LSA on 87.
sorta unrelated but kinda related
I know forged pistons have better detonation resistance which might be a plus. Is there any large draw backs the going with forged pistons over hyper cast? I understand they are louder, I'm more concerned about longevity. will the pistons be slapping after another 100k miles?
Thanks everyone
Thanks everyone
Plus If I ever want to turbo the Truck, all that has to be done is slap the old LQ4 heads back on.
I would not waste my time on 87 octane. 91 or E85 both allow for enough additional timing even on a 9.4:1 engine that I run both more economically than 87.
also, it's more of a winter daily truck, might haul a heavy car, wood, or scrap metal on a trailer once in a while. (I'd guess like 8k lbs max) in the summer I mostly ride my motorcycle, using the truck to go to motocross tracks on the weekends. So I'm not supper worried about loosing a slight bit of torque but I doubt with the added static CR that I actually would
Honestly at this point I'll probably have dished pistons similar to the stockers, with a TSP truck stage 3 for some peak HP but also to bleed off some DCR but still get good torque
I'm probably going with a 2800 - 3000rpm converter. Do you find yours is tight enough below the stall to drive nicely? how does it affect the trans Temps?
I live in Canada so 91 would have to be a fair bit more efficient to actually make it worth switching too. I calculated a difference of about 5L less per 100km was necessary in order to make to equal out costs. of course if 4 or 3L less would also put me in a better position because I wouldn't mind the extra 5 - 10$ per tank at that point. maybe I will do it know that I say that
anyways, how much more efficient did you find 91?
As for the converter I have driven trips of over 200 miles without getting over 2,500 rpm at any point. It is a little looser than the stock B82 in normal driving, but stalls about 400 rpm higher at WOT. With the way I have the TCC mapped the transmission temps were not changed. When it was 105*F outside and I was pulling 5,000 lbs it held 165*F.
