Motor specs
Old Feb 18, 2023 | 06:54 PM
Cabguy's Avatar
Default Motor specs
Is the 07 chevy classic truck 5.3 the same as the 02 chevy truck.5.3
Old Feb 18, 2023 | 07:07 PM
The 07 is Gen IV and uses a 58x reluctor, the 02 is Gen III and uses a 24x reluctor
Old Feb 18, 2023 | 07:10 PM
Cabguy's Avatar
Default Motor
I'm guess that's why the motor won't run correctly it runs but has a miss
Old Feb 18, 2023 | 08:31 PM
Be more specific please. If it even runs. you have the correct ECM
Old Feb 18, 2023 | 08:35 PM
Cabguy's Avatar
Default Tune
Yes the motor run but I'm have an issues with the passenger side staying cold like it's a dead miss the map /kpa won't read below 88 at idle if the rpm are 1300 it drops to 74 person that did the tune says it should be at 50
Old Feb 18, 2023 | 08:42 PM
Cabguy's Avatar
Default Tune
Could.i try putting in the correct sensor for the cam and crank I'm at a stopping piont right now until I can figure out what to do
Old Feb 18, 2023 | 10:38 PM
Which engine do you have? The 02 or 07? You never said.
Just make sure you always get the correct sensors for the Generation you have.
And please, avoid all the run-on sentences. VERY hard to make sense....
Old Feb 18, 2023 | 10:58 PM
Cabguy's Avatar
Default Tune
Sorry I have the 02 truck and ecm .motor came out of 07 classic and I didn't get the ecm with the motor
Old Feb 19, 2023 | 09:27 AM
aslack99's Avatar
If the motor runs at all, and your wiring harness matched up to the cam and crank sensors in the 2007 motor, it is probably a 24x motor since the truck it came out of was a Classic .
Old Feb 19, 2023 | 03:03 PM
Cabguy's Avatar
Default Tune
Well turns out the cam is no good time to pull the motor thanks for all the help
Old Feb 19, 2023 | 03:34 PM
Cabguy's Avatar
Default Cam
Any one tell me.what brand of can this is I believe it 1721 229 lift 236 duration
Old Feb 19, 2023 | 03:51 PM
There is no 229 lift. Both those numbers are likely duration.
You might do well to read up on engines in general, then LS engines in particular.
Old Feb 19, 2023 | 03:56 PM
Cabguy's Avatar
Default Cam
I'm sorry and I will do some reading and checking thank you
Old Feb 20, 2023 | 08:36 AM
Guy with a Chevy's Avatar
It's all good man you weren't impossible to understand. Photos always help too. You have to start somewhere
Old Feb 20, 2023 | 09:23 AM
Cabguy's Avatar
Default Tune
This is the cam i looked.it up say lq9
Old Feb 20, 2023 | 09:40 AM
The LQ9 cam is 196/201, ..467/.479, 116 LSA. FYI
The above specs are at .050 lift
Old Feb 20, 2023 | 10:38 AM
Cabguy's Avatar
Default Tune
I'm going to call texas speed and order what I need from then go from there
Old Feb 21, 2023 | 06:23 PM
grinder11's Avatar
Not being a smart *** at all, but I have to ask... why didn't you install the correct cam sensor and crank sensor from the get go? I must be missing something (wife would agree with that diagnosis!).
Old Feb 21, 2023 | 06:26 PM
grinder11's Avatar
I agree with Gary. Looks like a 229°/236° duration (@.050" lift) cam.
Old Feb 21, 2023 | 06:56 PM
Cabguy's Avatar
Default Tune
I check it had the right cam sensor and crank both are correct the cam was bad I can post a pic if like
