Balancing rotating assembly 6.0 question
Old Mar 10, 2023 | 11:07 AM
ColeSS's Avatar
Question Balancing rotating assembly 6.0 question
I'm doing a pretty basic rebuild on a LQ4/6.0, nothing crazy just standard bore with a BTR Truck Norris cam. Anyway the engine had a spun rod bearing on #5, so obviously the crank got beat up but its fine just had to go .10 under on it. But the #5 rod is obviously cooked as well and definitely needs to be replaced, the #6 rod is questionable so I figured I might as well replace it too. I'm just using the stock pistons and rods, so my question is should I worry about getting the engine rebalanced if I'm just replacing 2 rods with new stock rods?
Old Mar 10, 2023 | 11:40 AM
LS1Formulation's Avatar
I think you'll be fine. The GM powdered metal rods are much closer in weight than old school small block rods were, so it's doubtful you'll have any issues.
Old Mar 10, 2023 | 01:28 PM
ColeSS's Avatar
Awesome, I was thinking the same thing just wanted another opinion. Thank you sir!
Old Mar 10, 2023 | 06:51 PM
pdxmotorhead's Avatar
Doesn't hurt to throw each one on a scale... Just in case you got extra lucky...
