Oil Sump Design
Old Mar 22, 2023 | 01:30 PM
DWA_99's Avatar
Default Oil Sump Design
In the LS1, the bottom of the oil sump tube has what can only be described as a “restrictor plate.” It is a metal plate with a slit type opening.
What reason would GM have for putting that plate there? I understand not wanting the pump to suck the pan dry, but that could be solved with the Pressure Bypass Valve.
Old Mar 22, 2023 | 10:32 PM
dixiebandit69's Avatar
That "slot" can pass more oil than the pump can use. As far as why the end of the pickup tube has it, I would guess strength purposes.
Most engines have a similar design. Just run it.
Old Mar 22, 2023 | 11:33 PM
SSgtZ28's Avatar
If the inlet or diameter of the pickup tube is 20 - 30% larger than the inlet port on the pump, the tube will never become a restriction or cause cavitation inside the pump
The only function the screen or cover performs is to prevent big chunks of debris from being sucked into the oil pump.
