Help 6.0 with no power at all!
I have a 2008 Chevy Avalanche with 5.3 and I was happy with it till the day it decided to blow(2019).
I was looking for more power so I purchased a 6.0 L engine taken from 2013 Caprice. Engine has compression issues so I did a rebuild my self and installed an aftermarket camshaft (BTR stage 3) and don’t ask me why I chose this one because I really don’t know . Pushrods (7.400” x 080 WALL), double springs, chain and timing gear, high performance oil pump, Air intake, Ls3 intake manifold and injectors and Y pipe (It’s illegal to modify exhaust in my country) this is almost it.
Since the first start of the engine till today (September 2019 - now), everyday I hate the car more, even though it was the best thing in my life.
I didn’t gain any power, not even factory power, engine has a lot of problems. It will not start immediately and sometimes it will not start at all (cranks like it has low voltage). It will drive normally but when I’m flooring it will struggle and stall (backfires through intake manifold I think) but if I was gentle it would struggle less but still backfires. I can’t do an acceleration from zero (means no burnout)
Bad brakes (hard pedal)/ traction - stability warning
Smells like unburnd fuel
I have 3 codes ( P0336 P0335 P0300)
Changed crankshaft position sensor twice, then looked for wiring issues and found out that camshaft sensor wires were naked , after fixing the problem I didn’t get any codes except P0300 but all the symptoms are still happening all the time)
Fuel pressure checked
Checked for vacuum leaks
Checked compression (140 - 170 psi)
Changed sparks plugs ans wires
All my local mechanics don’t know what’s wrong. At this point the last engine has more power than this one , If anyone can help please let me know what should I do.
Thanks
Second... which BTR stage 3 cam are you talking about?? the truck stage 3? or the normal stage 3? BIG difference..
If you have decided to put the standard BTR stage 3 in a 7000 lb truck.... then you will never be happy with it.....
Even the Truck stage 3 is kinda big with stock stall converter with a 4L60E in my opinon..
Third..... it sounds like your timing is off like others have said.....
There are so many different things that can cause these problems, without more information and what has been checked. Everyone will just be guess, which is what most people do anyway.
I’m sure that the tuner tuned it for this cam because I told him all needed informations (unless he don’t know what to do)
I contacted with BTR to make sure and they said it must be dot to dot. But it could be one or two teeth off (everything is possible due to installation)
I didn’t measure the length of pushrods (it was tunner suggestion)
my plan was to upgrade TB and Headers but I must fix the problem first.
I’m waiting for the tunner to send the chart
The compression from 140-170 is a bit wide of a swing, which cylinders were low and which ones were higher? They should be pretty close to each other, unless you left this untouched prior to doing the cam swap knowing it had compression issues from the start..you should've addressed this 1st before doing all else and expecting a healthy running engine.
My last question is the tuner himself. Usually anytime a car comes in for a tune and the tuner asks you about the setup and they perform a tune. If the motor doesn't respond well..usually the tuner would point out various things of concern as to why he cant tune it, the tune isn't complete..its just patched enough to get you home and he would give you a list of things to look into and then bring it back for a reflash. Or the tuner just plugged in basic changes for a typical cam swap and sent you on your way regardless and said nothing then I wouldn't be going back to the same tuner.
Id say check the other easy things you can,especially anything you did yourself that might've been missed or slightly off. Cam timing off a tooth, rockers not fully seated or too tight, bad injectors or o-rings on the injectors, plug wires not fully on or bad coil/wiring. Check everything you touched. Usually its a stupid mistake that causes the most grief.
