Valve spring installed height/pressure
I have Ls1 short block, hand ported 799 heads with enginetech perfomance 2" and 1,571" valves (weight is same the as stock valves), TSP Torquer V4 cam, TSP PAC 660 dual spring kit. Going to spin engine 6800-7000 rpm.
What installed height/closed pressure should i shim the springs.
springs: install height 1.818
Closed pressure 160lb@1.810
Open pressure 415lb@.660lift
coil bind 1.015
Cam: 231/234@0.050
Valve lift 0.629 intake and 0.615 exhaust
Thanks.
