Should I worry about this Piston
Old May 19, 2023 | 11:40 AM
LQ4 Canada's Avatar
Default Should I worry about this Piston
Im rebuilding my first LS engine (2001 LQ4) and as I was cleaning the carbon off of a piston I noticed a small pit on the surface. Do I need to worry about it? Can I still use it? If not what are my options?
Thanks for reading my post!!!
Old May 19, 2023 | 12:04 PM
1FastBrick's Avatar
That depends, What are you doing with the engine?
You can also source another used piston.
Old May 19, 2023 | 01:06 PM
I'm not positive it's a problem. Possibly smooth any rough edges with small file or emery cloth.
Old May 19, 2023 | 01:31 PM
LQ4 Canada's Avatar
I’m using engine to go into a project car.
if I get another used piston, do I need to worry about being compatible with cylinder wear. I am honing cylinders.
Old May 19, 2023 | 02:57 PM
RB04Av's Avatar
Send it.
Old May 19, 2023 | 11:25 PM
01CamaroSSTx's Avatar
I'd be more concerned about running a used set of pistons if it were me but if P-W clearance is within spec's I suppose it would be okay.
Old May 20, 2023 | 05:04 AM
LQ4 Canada's Avatar
I agree. I definitely would have to check clearance with a used piston.
Old May 20, 2023 | 09:59 AM
Mr. Black's Avatar
I would take a dremel with a small carbide burr on it. The one with straight sides and rounded tip (not the one with a small ball on the end) and just smooth and blend it out a little.
Looks like a casting flaw from the factory???
